system controller bootmedia show-serial-number
Display the Boot Media Device serial number
The system controller bootmedia show-serial-number
command displays the Boot Media Device serial number. These commands are available for 80xx, 25xx and later systems. Earlier models are not supported. By default, the command displays the following information about the bootmedia:
Node name
Display name
Serial Number
Size
Bootmedia state
Status
To display more details, use the -instance
parameter.
[-fields <fieldname>,…]
Selects the fields that you specify.
[-instance ]
Displays detailed information for all the bootmedia devices.
[-node {<nodename>|local}]
- Node-
Selects the bootmedia device that is present on the specified node.
[-serial-num <text>]
- Serial Number-
Selects the bootmedia devices with the specified serial number.
[-vendor-id <Hex Integer>]
- Vendor ID-
Selects the bootmedia devices with the specified vendor ID.
[-device-id <Hex Integer>]
- Device ID-
Selects the bootmedia devices with the specified device ID.
[-display-name <text>]
- Display Name-
Selects the bootmedia devices with the specified display name.
[-unique-name <text>]
- Unique Name-
Selects the bootmedia device with the specified unique name.
[-monitor {node-connect|system-connect|system|controller|chassis|cluster-switch|example}]
- Health Monitor Name-
Selects the bootmedia devices with the specified health monitor.
[-usbmon-status {present|not-present}]
- Bootmedia Health Monitor-
Selects the bootmedia devices with the specified USBMON status.
[-device-state {good|warn|bad}]
- Bootmedia State-
Selects the bootmedia devices with the specified device state.
[-size <integer>]
- Max Memory Size (MB)-
Selects the bootmedia devices with the specified memory size.
[-health {ok|ok-with-suppressed|degraded|unreachable|unknown}]
- Status-
Selects the bootmedia devices with the specified health monitor status.
The following example displays the information of the bootmedia devices present in all the nodes in a cluster:
cluster1::> system controller bootmedia show-serial-number Node Display Name Serial Number (MB) State Status ------------- -------------------- ------------------- ------- --------- ------ or-12-01 BootMedia/SAMSUNG S2J4NXAGA08186 122104 good ok MZVLV128HCGR-00000 BootMedia-2/SAMSUNG S2J4NXAGA08198 122104 good ok MZVLV128HCGR-00000 2 entries were displayed.
The following example displays the detailed information about the bootmedia present in a node:
cluster1::> system controller bootmedia show-serial-number -instance -node node1 Node: node1 Vendor ID: 8086 Device ID: 8d02 Display Name: TOSHIBA THNSNJ060GMCU Unique Name: /dev/ad4s1 (TOSHIBA THNSNJ060GMCU) Health Monitor Name: controller Bootmedia Health Monitor: present Bootmedia State: good Max memory size(in MB): 16367 Status: ok Serial number: Y4IS104FTNEW
