lun portset create
Creates a new portset
This command creates a new port set for FCP and iSCSI. The port set name can include a maximum of 96 characters. You can add LIFs to the new port set. If you do not add a LIF to the port set, you create an empty port set. To add LIFs to an existing port set, use the lun portset add command.
After you create a port set, you must bind the port set to an igroup so the host knows which FC or iSCSI LIFs to access. If you do not bind an igroup to a port set, and you map a LUN to an igroup, then the initiators in the igroup can access the LUN on any LIF on the Vserver.
You cannot bind an igroup to an empty port set because the initiators in the igroup would have no LIFs to access the LUN. |
-vserver <Vserver Name>- Vserver Name-
Specifies the Vserver.
 -portset <text>- Portset Name-
Specifies the name of the new port set. A port set name is a case-sensitive name that must contain one to 96 characters. Spaces are not allowed.
 [-port-name <port_name>,…]- LIF Or TPG Name-
Specifies the name of the logical interface that you want to add to the portset you want to create.
[-protocol {mixed|fcp|iscsi}]- Protocol -
Specifies if the portset protocol type is
fcp,iscsi, ormixed. The default ismixed. - |
[-f, -fcp <true>]- FCP -
Specifies FCP as the protocol type of the new port set.
[-i, -iscsi <true>]- iSCSI } -
Specifies iSCSI as the protocol type of the new port set.
cluster1::> portset create -vserver vs1 -portset ps1 -protocol mixed
Creates a port set ps1 on Vserver vs1 with the protocol type of mixed .
cluster1::> portset create -vserver vs1 -portset iscsips -protocol iscsi
Creates a port set iscsips on Vserver vs1 with the protocol type of iscsi .
cluster1::> portset create -vserver vs1 -portset fcppc -protocol fcp
Creates a port set fcppc on Vserver vs1 with the protocol type of fcp .
cluster1::> portset create -vserver vs1 -portset ps2 -protocol mixed -port-name l11
Creates a port set ps2 on Vserver vs1 with the protocol type of mixed and LIF l11 .
