lun mapping delete
Unmap a LUN from an initiator group
This command unmaps a LUN from an initiator group. After you use this command, the LUN is not visible to any of the initiators in the initiator group.
-vserver <Vserver Name> - Vserver Name
Selects the LUN maps for the Vserver that matches the parameter value.
{ -path <path> - LUN Path
Specifies the path of the LUN you want to unmap. Examples of correct LUN paths are /vol/vol1/lun1 and /vol/vol1/qtree1/lun1 .
| -volume <volume name> - Volume Name
Specifies the volume of the LUN you want to unmap.
-qtree <qtree name> - Qtree Name
Specifies the qtree of the LUN you want to unmap.
-lun <text> - LUN Name }
Specifies the name of the LUN you want to unmap.
-g, -igroup <text> - Igroup Name
Specifies the initiator group that you want to unmap the LUN from.
cluster1::> lun mapping delete -vserver vs1 -path /vol/vol1/lun1 -igroup ig1
Unmaps LUN at path /vol/vol1/lun1 from the initiator group ig1 on Vserver vs1.
