The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage automated-working-set-analyzer stop
PDF of this doc site
Creating your file...
Your file is ready
Command to stop Automated Working Set Analyzer on node or aggregate
The storage automated-working-set-analyzer stop command terminates one or multiple Automated Workload Analyzer running instances.
-node <nodename>
- Node Name (privilege: advanced)-
This parameter indicates the node name that the AWA instance runs on.
[-flash-cache {true|false}]
- Flash cache node-wide modeling (privilege: advanced)-
This parameter indicates whether the AWA is modeling flash-cache.
[-aggregate <aggregate name>]
- Aggregate (privilege: advanced)-
This parameter indicates the aggregate name that the AWA instance runs on.
cluster1::> storage automated-working-set-analyzer stop -node vsim1 -aggregate aggr1
