system cluster-switch modify
Modify information about a switch's configuration
The ` system cluster-switch modify ` command modifies information about a cluster switch or management switch. The cluster switch health monitor uses this information to monitor the switch.
-device <text>- Device Name-
Specifies the device name of switch that you want to monitor.
[-address <IP Address>]- IP Address-
Specifies the IP address of switch's management interface.
[-snmp-version {SNMPv1|SNMPv2c|SNMPv3}]- SNMP Version-
Specifies the SNMP version that Data ONTAP uses to communicate with the switch. The default is SNMPv2c.
[-community <text>]- DEPRECATED-Community String or SNMPv3 Username -
This parameter is deprecated and may be removed in a future release of Data ONTAP. Use -community-or-usernameinstead.Specifies the community string for SNMPv2 authentication or SNMPv3 username for SNMPv3 security.
[-community-or-username <text>]- Community String or SNMPv3 Username } -
[-type {cluster-network|management-network}]- Switch Network-
Specifies the switch type.
[-is-monitoring-enabled-admin {true|false}]- Enable Switch Monitoring-
Specifies the switch admin monitoring status.
cluster1::> system cluster-switch modify -device SwitchA -address 2.3.4.5
Modifies the IP address for the switch named SwitchA.
cluster1::> system cluster-switch modify -device SwitchB -snmp-version SNMPv3 -community-or-username snmpv3u1
Modifies the SNMP parameters for the switch named SwitchB.
