security session limit application delete
Delete per-application session limit
This command allows deletion of a per-application management session limit.
-interface {cli|ontapi|rest} - Interface
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-application <text> - Application
The specified application to which this limit applies. The limit with the application name -default- is the limit used for any application without a specific configured limit.
The following example illustrates deleting a limit for management sessions from a custom application.
cluster1::*> security session limit application delete -interface ontapi -application "custom_app"
