vserver services web modify
PDF of this doc site
Creating your file...
Modify the configuration of web services
This command modifies the availability of the web services on Vservers. Only the services that are installed on every node in the cluster can be configured on Vservers whose type is not 'node'. Enabled services must include authorization configuration in the vserver services web access
command for the services to be externally available.
-vserver <Vserver Name>
- Vserver-
Identifies a Vserver for hosting a specific web service.
-name <text>
- Service Name-
Identifies the name of the web service.
[-enabled {true|false}]
- Enabled-
Defines the availability of a service on the Vserver. Disabled services are not accessible through the Vserver's network interfaces. This parameter's default value is dependent on the service. In general, services that provide commonly used features are enabled by default.
[-ssl-only {true|false}]
- SSL Only-
Defines the encryption enforcement policy for a service on the Vserver. Services for which this parameter is set to true support SSL only and cannot be used over unencrypted HTTP. The default for this value is 'false'.
The following command sets access to the web port to SSL only:
cluster1::> vserver services web modify -vserver vs1 -name portal -ssl-only true
