volume encryption secure-purge show
Show status of secure-purge operation on a volume
The volume encryption secure-purge show command displays information about volume encryption securepurge operation in the cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver (privilege: advanced)-
This parameter specifies the Vserver on which the volume is located.
[-volume <volume name>]- Volume (privilege: advanced)-
This parameter specifies the name of the volume being secure purged.
[-status {invalid|initializing|snapshots-deleting|snapshots-deleted|zombies-draining|zombies-drained|batched-free-log-draining|batched-free-log-drained|finishing-trash-purge|finished-trash-purge|reencrypting|aborting|aborted|success|failure}]- Status (privilege: advanced)-
This parameter displays the status of the secure purge operation.
The following example shows a sample output for this command:
cluster1::> volume encryption secure-purge show Vserver Volume Secure Purge Phase ----------- ------------- ---------------------- vs1 vol1 reencrypting
