network arp show
PDF of this doc site
Creating your file...
Display static ARP entries
The network arp show
command displays static ARP entries present in a given Vserver. This command will not display dynamically learnt ARP entries in the network stack. Use the network arp active-entry show command to display dynamically learned ARP entries in the network stack.
[-fields <fieldname>,…]
Use this parameter to display only certain fields of the ARP table.
[-instance ]
Use this parameter to display all the fields of the ARP table.
[-vserver <vserver name>]
- Vserver Name-
Use this parameter to display ARP entries that are specific to a given Vserver.
[-remotehost <IP Address>]
- Remote IP Address-
Use this parameter to display ARP entries for the specified IP address
[-mac <MAC Address>]
- MAC Address-
Use this parameter to display ARP entry for the specified MAC address
[-ipspace <IPspace>]
- IPspace-
Use this parameter to specify the IPspace associated with the Vserver
The following example displays static ARP entries from the Vserver vs1.
cluster1::> network arp show -vserver vs1 Vserver Remote Host MAC Address ----------- ----------------- ----------------- vs1 10.238.0.2 40:55:39:25:27:c1
