vserver cifs home-directory search-path show
Display home directory search paths
The vserver cifs home-directory search-path show command displays information about the search paths that are in the home directory configuration for the CIFS-enabled Vservers.
[-fields <fieldname>,…] -
If you specify this parameter, the command only displays the fields that you specify.
[-instance ]} -
If you specify the -instance parameter, the command displays detailed information about all entries.
 [-vserver <vserver name>]- Vserver-
If you specify this parameter, the command displays home directory configuration for the CIFS-enabled Vserver that you specify.
 [-path <text>]- Path-
If you specify this parameter, the command displays information only for the search path that you specify.
The following example displays information about search paths for all CIFS home directories on all CIFS-enabled Vservers:
cluster1::> vserver cifs home-directory search-path show Vserver Position Path ----------- -------- ----------------- vs1 1 /home1 vs2 2 /home2
