vserver cifs home-directory show
Display home directory configurations
The vserver cifs home-directory show command displays the CIFS home directory configuration for one or more Vservers.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver>]- Vserver-
If you specify this parameter, the command displays CIFS home directory configuration for the specified Vserver.
[-is-home-dirs-access-for-admin-enabled {true|false}]- Is Home Directory Access for Admin Enabled-
If you specify this parameter, the command displays home directory configuration for CIFS servers that have the specified setting.
[-is-home-dirs-access-for-public-enabled {true|false}]- Is Home Directory Access for Public Enabled (privilege: advanced)-
The following example lists the CIFS home directory configuration for a Vserver on the cluster.
cluster1::> vserver cifs home-directory show -vserver vs1 Vserver: vs1 Is Home Directory Access for Admin Enabled: true
