vserver cifs domain name-mapping-search show
PDF of this doc site
Creating your file...
Display the list of trusted domains for name-mapping searches
The vserver cifs domain name-mapping-search show
command displays information about trusted domains of the home domain by Vserver.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
This parameter specifies the name of the Vserver for which you want to display information about the trusted domains.
[-trusted-domains <domain name>,…]
- Trusted domains-
This parameter specifies a comma-delimited list of fully qualified domain names of trusted domains for which you want to display information.
The following example displays information about all preferred trusted domains:
cluster1::> vserver cifs domain name-mapping-search show Vserver Trusted Domains -------------- ---------------------------------- vserver_1 CIFS1.EXAMPLE.COM
