The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver nvme subsystem map remove
PDF of this doc site
Creating your file...
Your file is ready
Remove a namespace map
The vserver nvme subsystem map remove
command deletes an association on an NVMe namespace to an NVMe subsystem.
-vserver <Vserver Name>
- Vserver Name-
Specifies the Vserver.
-subsystem <text>
- Subsystem-
Specifies the NVMe target subsystem.
-path <path>
- Namespace Path-
Specifies the path of the NVMe namespace. Examples of correct NVMe namespace paths are
/vol/vol1/ns1
and/vol/vol1/qtree1/ns1
cluster::*> vserver nvme subsystem map remove -vserver vs_1 -subsystem sub_1 -path /vol/nsvol/namespace1
Removes the association on the NVMe namespace at the specified path to NVMe subsystem sub_1
on Vserver vs_1
