ONTAP commands
volume encryption rekey start
Start a volume encryption rekey operation
The volume encryption rekey start command changes the encryption key of a volume.
-vserver <vserver name> - Vserver Name
This parameter specifies the Vserver on which the volume is located.
-volume <volume name> - Volume Name
This parameter specifies the name of the volume being rekeyed.
[-ignore-warning {true|false}] - Ignore Warning for Rekey Start
If this parameter is set, the command ignores the confirmation message.
