The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system controller clus-flap-threshold show
PDF of this doc site
Creating your file...
Your file is ready
Display the controller cluster port flap threshold
The system controller clus-flap-threshold show
command allows the display of the threshold for link flapping counts for all nodes. This threshold would be the number of times the cluster port links for a given node can flap (go down) within a polling period before triggering an alert.
