network bgp config delete
Delete BGP configuration
The network bgp config delete
command deletes a node’s border gateway protocol (BGP) configuration. A BGP configuation cannot be deleted if there are BGP peer groups configured on the associated node.
-node {<nodename>|local}
- Node-
This parameter specifies the node for which the BGP configuration will be deleted.
cluster1::> network bgp config delete -node node1
