      system services ndmp off
(DEPRECATED)-Disable NDMP service
This node-scoped NDMP command is deprecated. Node-scoped NDMP functionality may be removed in a future release of Data ONTAP. Use the Vserver-aware "vserver services ndmp off " command. |
The system services ndmp off command is used to disable the NDMP service on any node in the cluster.
-node {<nodename>|local}- Node-
The specific node on which NDMP service is to be disabled.
The following example is used to turn off the NDMP service on node named node1:
cluster1::> system services ndmp off -node node1
