storage aggregate object-store show
Display the details of object stores attached to an aggregate
The storage aggregate object-store show command displays information about all the object stores in the system.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-aggregate <text>]- Aggregate Name-
If this parameter is specified, the command displays information only about the object stores that are attached to the specified aggregates.
[-object-store-name <text>]- ONTAP Name for this Object Store Config-
If this parameter is specified, the command displays information only about object stores whose configuration name matches the specified names.
[-object-store-availability <object Store Availability>]- Availability of the Object Store-
If this parameter is specified, the command displays information only about object stores whose availability status matches the specified value. Supported values with this parameter are - available and unavailable.
[-provider-type <providerType>]- Type of the Object Store Provider-
If this parameter is specified, the command displays information only about object store configurations whose provider type matches the specified value.
[-license-used-percent <percent_no_limit>]- License Space Used Percent-
If this parameter is specified, the command displays information only about object stores whose space used by the aggregate as a percentage of the license limit matches the specified value.
[-unreclaimed-space-threshold <percent>]- Threshold for Reclaiming Unreferenced Space (privilege: advanced)-
If this parameter is specified, the command displays information only about object stores whose threshold for reclaiming unused space from objects in the object store matches the specified value.
[-tiering-fullness-threshold <percent>]- Aggregate Fullness Threshold Required for Tiering (privilege: advanced)-
If this parameter is specified, the command displays information only about object stores whose performance tier fullness threshold for tiering matches the specified value.
The following example displays all information about all object stores:
cluster1::>storage aggregate object-store show
