storage port enable
Enable a storage port
The storage port enable
command enables a specified storage port.
-node {<nodename>|local}
- Node-
Use this parameter to specify the node on which the port resides.
-port <text>
- Port-
Use this parameter to specify the port that needs to be enabled.
The following example enables port 0a on node node1:
cluster1::> storage port enable -node node1 -port 0a
