The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
security session limit request delete
PDF of this doc site
Creating your file...
Your file is ready
Delete per-request session limit
This command allows deletion of a per-request management session limit.
-interface {cli|ontapi|rest}
- Interface (privilege: advanced)-
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-request <text>
- Request Name (privilege: advanced)-
The specified request to which this limit applies. The limit with the request name
-default-
is the limit used for any request without a specific configured limit.
The following example illustrates deleting custom limits for that were configured for the volume commands and APIs.
cluster1::*> security session limit request delete -interface * -request volume* 4 entries were deleted.
