ONTAP commands
storage iscsi-initiator disconnect
Disconnect from an iSCSI target
The storage iscsi-initiator disconnect command disconnects a node from the specified target. This command is only supported on high-availability shared-nothing virtualized platforms.
-node {<nodename>|local} - Node (privilege: advanced)
Specifies the name of the Data ONTAP node from which the iSCSI target will be disconnected.
[-target-type {external|mailbox|partner|partner2|dr_auxiliary|dr_partner}] - Target Type (privilege: advanced)
Selects targets with the specified target type.
-label <text> - User Defined Identifier (privilege: advanced)
Specifies the label of the target to disconnect from.
The following example adds and connects to an iSCSI target from the specified node.
cluster1::*> storage iscsi-initiator disconnect -node node1
             -label target1
