The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system node image package delete
PDF of this doc site
Creating your file...
Your file is ready
Delete a software package
The delete command will delete the specified software package.
-node {<nodename>|local}
- Node (privilege: advanced)-
The package will be deleted from the repository belonging to the node specified with this parameter. The local node is used as the default if this parameter is omitted.
-package <text>
- Package File Name (privilege: advanced)-
This parameter specifies the package to be deleted.
::> system image package delete image.tgz 1 entry was deleted.
