vserver vscan on-demand-task show
Display On-Demand tasks
The vserver vscan on-demand-task show
command displays information about the On-Demand tasks belonging to the Vserver. If you do not specify any parameters, the command displays the following information about all On-Demand tasks:
Vserver name
Task name
Scan paths
Report directory path
Schedule
You can specify the -fields
parameter to specify which fields of information to display about On-Demand tasks. In addition to the fields above, you can display the following fields:
Max file size
File paths to exclude
File extensions to exclude
File extensions to include
Scan files without extension
Scan timeout
Cross junction
Directory recursion
Scan priority
Report log level
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-vserver <vserver name>]
- Vserver-
If you specify this parameter, the command displays information only about the On-Demand tasks for the specified Vserver.
[-task-name <text>]
- Task Name-
If you specify this parameter, the command displays information only about the specified On-Demand task.
[-scan-paths <text>,…]
- List of Scan Paths-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified path or paths in the scan-paths list.
[-report-directory <text>]
- Report Directory Path-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified report-directory.
[-schedule <text>]
- Job Schedule-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified schedule.
[-max-file-size {<integer>[KB|MB|GB|TB|PB]}]
- Max File Size Allowed for Scanning-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified max-file-size.
[-paths-to-exclude <text>,…]
- File Paths Not to Scan-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified path or paths in the exclude list.
[-file-ext-to-exclude <File extension>,…]
- File Extensions Not to Scan-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified file extension or extensions in the exclude list.
[-file-ext-to-include <File extension>,…]
- File Extensions to Scan-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified file extension or extensions in the include list.
[-scan-files-with-no-ext {true|false}]
- Scan Files with No Extension-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified value.
[-request-timeout <[<integer>h][<integer>m][<integer>s]>]
- Request Service Timeout-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified request-timeout.
[-cross-junction {true|false}]
- Cross Junction-
[-directory-recursion {true|false}]
- Directory Recursion-
[-scan-priority {low|normal}]
- Scan Priority-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified scan-priority.
[-report-log-level {verbose|info|error}]
- Report Log Level-
If you specify this parameter, the command displays information only about the On-Demand tasks that have the specified report-log-level.
The following example displays information about all On-Demand tasks:
cluster1::> vserver vscan on-demand-task show Report Vserver Task Name Scan Paths Directory Path Schedule ----------- ---------- -------------------- ----------------- -------------- vs1 t1 /test /report - vs2 t2 /, /test/ /report daily 2 entries were displayed.
The following example displays detailed information about an On-Demand task:
cluster1::> vserver vscan on-demand-task show -instance -vserver vs1 -task-name t1 Vserver: vs1 Task Name: t1 List of Scan Paths: /test Report Directory Path: /report Job Schedule: - Max File Size Allowed for Scanning: 2GB File Paths Not to Scan: /vol1/cold-files/ File Extensions Not to Scan: mp3, mp4 File Extensions to Scan: * Scan Files with No Extension: true Request Service Timeout: 1m Cross Junction: true Directory Recursion: true Scan Priority: low Report Log Level: verbose
