system license show-aggregates
PDF of this doc site
Creating your file...
Display status of aggregates leases and license used.
This command displays the status of all ONTAP aggregates.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
If you use this parameter, the command displays information only about aggregates that match the given node.
[-aggr-name <text>]
- Aggregate Name-
If you use this parameter, the command displays information only about aggregate that match the given aggregate.
[-aggr-size {<integer>[KB|MB|GB|TB|PB]}]
- Aggregate Size-
If you use this parameter, the command displays information only about aggregates that match the given physical size of an aggregate.
[-licensed-size {<integer>[KB|MB|GB|TB|PB]}]
- Licensed Size-
If you use this parameter, the command displays information only about aggregates that match the given licensed-size.
[-expiration <MM/DD/YYYY HH:MM:SS>]
- Lease Expiration-
If you use this parameter, the command displays information only about aggregates that match the given lease expiration.
[-status <AggrLicStatus>]
- Aggregate Status-
If you use this parameter, the command displays information only about aggregates that match the given status.
[-compliant {true|false}]
- Is Aggregate Compliant-
If you use this parameter, the command displays information only about aggregates that match the given state of compliance.
[-aggr-uuid <UUID>]
- Aggregate UUID-
If you use this parameter, the command displays information only about aggregate that match the given aggregate uuid.
The following example displays the license status of the cluster:
cluster1::> system license show-aggregates Licensed Physical Node Aggregate Size Size Lease Expiration Status --------- ------------------- -------- -------- ------------------ ------------ node1 root1 0B 2GB - lease-not-required root2 (mirror) 0B 2GB - lease-not-required aggr1 20GB 20GB 6/21/2018 18:10:00 lease-up-to-date aggr2 (mirror) 10GB 10GB 6/21/2018 20:00:00 lease-up-to-date node2 root1 (mirror) 0B 2GB - lease-not-required root2 0B 2GB - lease-not-required aggr1 (mirror) 20GB 20GB 6/21/2018 18:10:00 lease-up-to-date aggr2 10GB 10GB 6/21/2018 20:00:00 lease-up-to-date node3 root3 0B 2GB - lease-not-required root4 (mirror) 0B 2GB - lease-not-required aggr3 15GB 0B 6/21/2018 20:00:00 aggregate-deleted aggr4 (mirror) 15GB 15GB 6/21/2018 12:00:00 lease-expired aggr5 (mirror) 15GB 15GB 6/21/2018 21:00:00 lease-up-to-date aggr6 15GB 15GB 6/21/2018 21:00:00 plex-deleted aggr7 15GB 14GB 6/21/2018 21:00:00 aggregate-license-size-decreased aggr8 (mirror) 0B 14GB - lease-missing node4 root3 (mirror) 0B 2GB - lease-not-required root4 0B 2GB - lease-not-required aggr3 (mirror) 15GB 0B 6/21/2018 20:00:00 aggregate-deleted aggr4 15GB 15GB 6/21/2018 12:00:00 lease-expired aggr5 15GB 15GB 6/21/2018 21:00:00 lease-up-to-date aggr6 (mirror) 15GB 0B 6/21/2018 21:00:00 plex-deleted aggr7 (mirror) 15GB 14GB 6/21/2018 21:00:00 aggregate-license-size-decreased aggr8 0B 14GB - lease-missing
