ONTAP commands
system license show-aggregates
Display status of aggregates leases and license used.
This command displays the status of all ONTAP aggregates.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-node {<nodename>|local}] - Node
If you use this parameter, the command displays information only about aggregates that match the given node.
[-aggr-name <text>] - Aggregate Name
If you use this parameter, the command displays information only about aggregate that match the given aggregate.
[-aggr-size {<integer>[KB|MB|GB|TB|PB]}] - Aggregate Size
If you use this parameter, the command displays information only about aggregates that match the given physical size of an aggregate.
[-licensed-size {<integer>[KB|MB|GB|TB|PB]}] - Licensed Size
If you use this parameter, the command displays information only about aggregates that match the given licensed-size.
[-expiration <MM/DD/YYYY HH:MM:SS>] - Lease Expiration
If you use this parameter, the command displays information only about aggregates that match the given lease expiration.
[-status <AggrLicStatus>] - Aggregate Status
If you use this parameter, the command displays information only about aggregates that match the given status.
[-compliant {true|false}] - Is Aggregate Compliant
If you use this parameter, the command displays information only about aggregates that match the given state of compliance.
[-aggr-uuid <UUID>] - Aggregate UUID
If you use this parameter, the command displays information only about aggregate that match the given aggregate uuid.
The following example displays the license status of the cluster:
cluster1::> system license show-aggregates
Licensed Physical
Node      Aggregate               Size     Size Lease Expiration   Status
node1
          root1                     0B      2GB -                  lease-not-required
          root2 (mirror)            0B      2GB -                  lease-not-required
          aggr1                   20GB     20GB 6/21/2018 18:10:00 lease-up-to-date
          aggr2 (mirror)          10GB     10GB 6/21/2018 20:00:00 lease-up-to-date
node2
          root1 (mirror)            0B      2GB -                  lease-not-required
          root2                     0B      2GB -                  lease-not-required
          aggr1 (mirror)          20GB     20GB 6/21/2018 18:10:00 lease-up-to-date
          aggr2                   10GB     10GB 6/21/2018 20:00:00 lease-up-to-date
node3
          root3                     0B      2GB -                  lease-not-required
          root4 (mirror)            0B      2GB -                  lease-not-required
          aggr3                   15GB       0B 6/21/2018 20:00:00 aggregate-deleted
          aggr4 (mirror)          15GB     15GB 6/21/2018 12:00:00 lease-expired
          aggr5 (mirror)          15GB     15GB 6/21/2018 21:00:00 lease-up-to-date
          aggr6                   15GB     15GB 6/21/2018 21:00:00 plex-deleted
          aggr7                   15GB     14GB 6/21/2018 21:00:00 aggregate-license-size-decreased
          aggr8 (mirror)            0B     14GB -                  lease-missing
node4
          root3 (mirror)            0B      2GB -                  lease-not-required
          root4                     0B      2GB -                  lease-not-required
          aggr3 (mirror)          15GB       0B 6/21/2018 20:00:00 aggregate-deleted
          aggr4                   15GB     15GB 6/21/2018 12:00:00 lease-expired
          aggr5                   15GB     15GB 6/21/2018 21:00:00 lease-up-to-date
          aggr6 (mirror)          15GB       0B 6/21/2018 21:00:00 plex-deleted
          aggr7 (mirror)          15GB     14GB 6/21/2018 21:00:00 aggregate-license-size-decreased
          aggr8                     0B     14GB -                  lease-missing
