The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
network options ipv6 modify
PDF of this doc site
Creating your file...
Your file is ready
Modify IPv6 options
This command sets the state of IPv6 options for the cluster.
[-enabled <true>]
- IPv6 Enabled-
Setting this parameter to
true
enables IPv6 for the cluster. IPv6 cannot be disabled once it is enabled for the cluster. Call technical support for guidance regarding disabling IPv6. [-is-ra-processing-enabled {true|false}]
- Router Advertisement (RA) Processing Enabled-
true
enables cluster to process IPv6 router advertisements. Setting it tofalse
disables router advertisement processing by the cluster.
The following example enables IPv6 for the cluster: cluster1::> network options ipv6 modify -enabled true The following example enables IPv6 Router Advertisement processing for the cluster: cluster1::> network options ipv6 modify -is-ra-processing-enabled true The following example disables IPv6 Router Advertisement processing for the cluster: cluster1::> network options ipv6 modify -is-ra-processing-enabled false
