storage aggregate efficiency cross-volume-dedupe show
Display aggregate cross volume deduplication efficiency details
The storage aggregate efficiency cross-volume-dedupe show command displays information in detail about the different storage efficiency of all the aggregates.If no parameters are specified, the command displays the following information for all aggregates:
{ [-fields <fieldname>,…​]
| [-instance ] }
[-aggregate <aggregate name>] - Aggregate
Displays the aggregate name. If this parameter is specified, the command displays detailed information about the storage efficiency of the specified aggregate.
[-node {<nodename>|local}] - Node
Displays the node which owns the aggregate. If this parameter is specified, the command displays storage efficiency information only about the aggregates that are located on the specified node.
[-background-progress <text>] - Progress
Displays the information for the aggregates that match the specified progress.
[-background-op-status <text>] - Operation Status
Displays the information for the aggregates that match the specified operation status.
[-background-last-op-state <text>] - Last Operation State
Displays the information for the aggregates that match the specified last operation state.
[-background-last-success-op-begin <Date>] - Last Success Operation Begin Time
Displays the information for the aggregates that match the specified last successful operation begin time.
[-background-last-success-op-end <Date>] - Last Success Operation End Time
Displays the information for the aggregates that match the specified last successful operation end time.
[-background-last-op-begin <Date>] - Last Operation Begin Time
Displays the information for the aggregates that match the specified last operation begin time.
[-background-last-op-end <Date>] - Last Operation End Time
Displays the information for the aggregates that match the specified last operation end time.
[-background-last-op-error <text>] - Last Operation Error
Displays the information for the aggregates that match the specified last operation error.
[-background-stage <text>] - Stage
Displays the information for the aggregates that match the specified stage.
[-background-checkpoint-time <Date>] - Checkpoint Time
Displays the information for the aggregates that match the specified checkpoint time.
[-background-checkpoint-op-type <text>] - Checkpoint Operation Type
Displays the information for the aggregates that match the specified checkpoint operation type.
[-background-checkpoint-stage <text>] - Checkpoint Stage
Displays the information for the aggregates that match the specified checkpoint stage.
[-background-dedupe {true|false}] - Background State
Displays the information for the aggregates that match the specified cross volume background dedupe state.
[-inline-dedupe {true|false}] - Inline State
Displays the information for the aggregates that match the specified cross volume inline dedupe state.
[-dedupe-savings {true|false}] - Has Cross Volume Deduplication Savings
Displays the information for the aggregates that has some savings from cross volume deduplication.
The following example displays information about all aggregates that are owned by nodes in the local cluster:
cluster:::> storage aggregate efficiency cross-volume-dedupe show
Aggregate: aggr0
     Node: vivek6-vsim2
Has Cross Volume Deduplication Savings:                        false
--------:Cross Volume Background Deduplication Status:--------
State:                                                         false
Progress:                                                      -
Operation Status:                                              Idle
Last Operation State:                                          Success
Last Success Operation Begin Time:                             -
Last Success Operation End Time:                               -
Last Operation Begin Time:                                     -
Last Operation End Time:                                       -
Last Operation Error:                                          Operation succeeded
Stage:                                                         -
Checkpoint Time:                                               -
Checkpoint Operation Type:                                     -
Checkpoint Stage:                                              -
-----------:Cross Volume Inline Deduplication Status:---------
State:                                                         false
Aggregate: aggr1
     Node: vivek6-vsim2
Has Cross Volume Deduplication Savings:                        true
State:                                                         true
Progress:                                                      -
Last Success Operation Begin Time:                             Wed Aug 30 06:31:50 2017
Last Success Operation End Time:                               Wed Aug 30 06:31:50 2017
Last Operation Begin Time:                                     Wed Aug 30 06:31:50 2017
Last Operation End Time:                                       Wed Aug 30 06:31:50 2017
Stage:                                                         Cross volume sharing Done
Checkpoint Time:                                               -
Checkpoint Stage:                                              -
State:                                                         true
2 entries were displayed.
