vserver name-mapping swap
Exchange the positions of two name mappings
The vserver name-mapping swap
command exchanges the positions of two name mappings in the priority list.
-vserver <vserver name>
- Vserver-
This parameter specifies the Vserver on which the name mappings are located.
-direction {krb-unix|win-unix|unix-win}
- Direction-
This parameter specifies the direction of the name mappings that you want to exchange. Each mapping direction (Kerberos-to-UNIX, Windows-to-UNIX, and UNIX-to-Windows) has its own priority list.
-position <integer>
- Position-
This parameter specifies the position in the priority list of the first name mapping that you want to exchange. Specify a position as a positive integer.
-with-position <integer>
- Position of an existing name mapping entry in the list of name mappings for this Vserver. This entry will be swapped with the entry at 'position'.-
This parameter specifies the position in the priority list of the second name mapping that you want to exchange. Specify a position as a positive integer.
The following example exchanges the positions of two name mappings on a Vserver named vs1. The name mappings have the direction Windows-to-UNIX. The name mappings are exchanged between positions 2 and 4.
cluster1::> vserver name-mapping swap -vserver vs1 -direction win-unix -position 2 -with-position 4
