metrocluster configuration-settings interface show
Display the network logical interfaces provisioned for MetroCluster
The metrocluster configuration-settings interface show command displays the network logical interfaces that were provisioned for MetroCluster.
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-instance ]} -
If this parameter is specified, the command displays detailed information about all entries.
 [-dr-group-id <integer>]- DR Group ID-
If this parameter is specified, the command displays information for the matching DR group.
 [-cluster-uuid <UUID>]- Cluster UUID-
If this parameter is specified, the command displays information for the matching cluster specified by uuid.
 [-cluster <Cluster name>]- Cluster Name-
If this parameter is specified, the command displays information for the matching cluster..
 [-node-uuid <UUID>]- Node UUID-
If this parameter is specified, the command displays information for the matching nodes uuid.
 [-node <text>]- Node Name-
If this parameter is specified, the command displays information for the matching nodes.
 [-home-port {<netport>|<ifgrp>}]- Home Port-
If this parameter is specified, all interfaces with home-port set to this value are displayed.
 [-address <IP Address>]- Network Address-
If this parameter is specified, the command displays information for the matching network address.
 [-netmask <Contiguous IP Mask>]- Netmask-
If this parameter is specified, all interfaces with netmask set to this value are displayed.
 [-gateway <IP Address>]- Gateway-
If this parameter is specified, all interfaces with gateway set to this value are displayed.
 [-config-state <text>]- Configuration State-
If this parameter is specified, all interfaces with this field set to the specified value are displayed.
 [-config-error-info <text>]- Configuration Error Information-
The following example illustrates display of logical interfaces configured in a four-node MetroCluster setup:
clusA::> metrocluster configuration-settings interface show
DR        Config
Group Cluster Node    Network Address Netmask         Gateway         State
1     clusA A1
                 Home Port: e0f
                      10.140.113.214  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.215  255.255.192.0   -               completed
                       A2
                 Home Port: e0f
                      10.140.113.216  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.217  255.255.192.0   -               completed
      clusB B2
                 Home Port: e0f
                      10.140.113.249  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.25   255.255.192.0   -               completed
                       B1
                 Home Port: e0f
                      10.140.113.218  255.255.192.0   -               completed
                 Home Port: e0g
                      10.140.113.248  255.255.192.0   -               completed
8 entries were displayed.
