snaplock legal-hold show
Show status of a legal-hold operation.
The snaplock legal-hold show command displays the status of a legal-hold operation. Information about completed operations will be cleaned up after an hour of completion. Only a user with security login role vsadmin-snaplock is allowed to perform this operation.
{ [-fields <fieldname>,…​]
| [-instance ] }
[-vserver <vserver name>] - Vserver Name
If this parameter is specified, the command displays all legal-hold operations that match the specified Vserver.
[-operation-id <integer>] - Operation ID
If this parameter is specified, the command displays all legal-hold operations that match the specified operation ID.
[-volume <volume name>] - Volume Name
If this parameter is specified, the command displays all legal-hold operations that match the specified volume. The parameter specifies the volume on which legal-hold operation is running or has completed.
[-path <text>] - Path
If this parameter is specified, the command displays all legal-hold operations that match the specified path. The parameter specifies the path on which legal-hold operation is running or has completed.
[-litigation-name <text>] - Litigation Name
If this parameter is specified, the command displays all legal-hold operations that match the specified litigation name. The parameter specifies the legal-hold litigation name.
[-operation-type {unknown|begin|end|dump-files}] - Operation Type
If this parameter is specified, the command displays all legal-hold operations that match the specified operation type. The parameter specifies the type of legal-hold operation.
[-operation-status {Unknown|In-Progress|Failed|Aborting|Completed}] - Operation Status
If this parameter is specified, the command displays all legal-hold operations that match the specified operation status. The parameter specifies the status of legal-hold operation.
[-num-files-processed <integer>] - Number of Files Processed
If this parameter is specified, the command displays all legal-hold operations that match the specified number of files processed. The parameter specifies the number of files on which legal-hold operation was successful.
[-num-files-failed <integer>] - Number of Files Failed
If this parameter is specified, the command displays all legal-hold operations that match the specified number of files failed. The parameter specifies the number of files on which legal-hold operation failed.
[-num-files-skipped <integer>] - Number of Files Skipped
If this parameter is specified, the command displays all legal-hold operations that match the specified number of files skipped.
The parameter specifies the number of files on which legal-hold begin operation was skipped. The legal-hold begin operation is skipped on a file if it is already under hold for a given litigation or if it is a hard link to a file that is already under hold for a given litigation.
[-num-inodes-ignored <integer>] - Number of Inodes Ignored
If this parameter is specified, the command displays all legal-hold operations that match the specified number of inodes ignored. The parameter specifies the number of inodes on which the legal-hold operation was not attempted because they were not regular files.
[-status-details <text>] - Status Details
If this parameter is specified, the command displays all legal-hold operations that match the specified status details. The parameter specifies the status details of an legal-hold operation.
The following examples show the status of legal-hold operations for Vserver vs1 and volume slc_vol1 and the status of legal-hold operation for operation ID 16842786 respectively:
vs1::> snaplock legal-hold show -volume slc_vol1
                                                Operation
Operation     Operation ID    Vserver   Volume  Status
begin         16842784        vs1       slc_vol1
                                                Completed
begin         16842786        vs1       slc_vol1
                                                Completed
begin         16842788        vs1       slc_vol1
                                                In-Progress
dump-files    16842790        vs1       slc_vol1
                                                Completed
end           16842794        vs1       slc_vol1
                                                Completed
5 entries were displayed.
vs1::> snaplock legal-hold show -operation-id 16842786
Vserver: vs1
                      Volume: slc_vol1
                Operation ID: 16842786
             Litigation Name: litigation1
                        Path: /
              Operation Type: begin
                      Status: Completed
   Number of Files Processed: 100
      Number of Files Failed: 15
     Number of Files Skipped: 20
    Number of Inodes Ignored: 0
              Status Details: No error
