The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
application provisioning config modify
PDF of this doc site
Creating your file...
Your file is ready
Modify options for application provisioning
This command modifies the options for application provisioning operations.
[-is-mixed-storage-services-allowed {true|false}]
- Is Mixed Storage Services Allowed (privilege: advanced)-
Specifies whether mixed cost storage services are allowed for provisioning placement. If the value of this parameter is
false
, only the aggregates closest to the performance requirements of the storage service are used. If the value of this parameter istrue
, all aggregates with sufficient performance are considered. The initial value for option isfalse
cluster1::*> application provisioning config modify -is-mixed-storage-services-allowed true
Enables the use of mixed storage services for provisioning placement.
