system services ndmp kill-all
Kill all NDMP sessions
The system services ndmp kill-all command is used to terminate all NDMP sessions on a particular node in the cluster.
-node {<nodename>|local} - Node
Node on which all NDMP sessions needs to be terminated.
The following example shows how all NDMP sessions on the node named node1 can be terminated:
cluster1::> system services ndmp kill-all -node node1
