metrocluster operation show
Display details of the last MetroCluster operation
The metrocluster operation show command displays information about the most recent MetroCluster operation run on the local cluster.
This command will display information about all MetroCluster commands except for the commands in the metrocluster check directory. This command will not display any information after MetroCluster has been completely unconfigured using the metrocluster unconfigure command.
The following example shows the output of metrocluster operation show after running a metrocluster configure command was successful:
clusA::> metrocluster operation show
Operation: configure
State: successful
Start time: 2/15/2013 18:22:46
End time: 2/15/2013 18:25:18
Errors: -
