volume flexcache origin show-caches
Display all the caches connected to origin
The volume flexcache origin show-caches command displays FlexCache relationships for origin of a FlexCache volumes on the origin cluster.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-origin-vserver <vserver name>]- Vserver-
If this parameter and the
origin-volumeparameter are specified, the command displays the FlexCache relationship for the specified origin of a FlexCache volume. If this parameter is specified by itself, the command displays all the FlexCache relationships for all origin of a FlexCache volumes in the specified Vserver. [-origin-volume <volume name>]- Origin Volume-
If this parameter is specified, the command displays all the FlexCache relationships for the specified origin of a FlexCache volume.
[-cache-vserver <vserver name>]- Cache Vserver-
If this parameter is specified then the command displays FlexCache relationships for the specified Vserver hosting FlexCache volumes.
[-cache-volume <volume name>]- Cache Volume-
If this parameter is specified then the command displays FlexCache relationships for the specified FlexCache volume.
[-cache-cluster <Cluster name>]- Cache Cluster-
If this parameter is specified then the command displays FlexCache relationships for the specified cluster hosting FlexCache volumes.
[-cache-volume-msid <integer>]- Cache Volume MSID-
If this parameter is specified then the command displays FlexCache relationships for the specified FlexCache volume's FlexGroup master data-set ID.
[-relationship-create-time <Date>]- Relationship Create Time-
If you specify this parameter, the command displays FlexCache relationships for which the
relationship-create-timeoption matches the specified input.
The following example displays information about all origin of a FlexCache volumes on the Vserver named vs34:
cluster1::> flexcache origin show-caches -origin-vserver vs34
(volume flexcache origin show-caches)
Origin-Vserver Origin-Volume Cache-Vserver Cache-Volume Cache-Cluster
vs34 origin1 vs56 fc1_c3_origin1
cluster-3
vs34 origin1 vs34 fc1 cluster-2
vs34 origin1 vs34 fc2 cluster-2
vs34 origin2_new vs56 fc1_c3_origin2
cluster-3
4 entries were displayed.
cluster1::> flexcache origin show-caches -origin-vserver vs56 -instance
Vserver: vs56
Origin Volume: origin
Cache Vserver: vs56
Cache Volume: fc1
Cache Cluster: cluster-3
Cache Volume MSID: 2156002002
Relationship Create Time: Thu Aug 23 04:36:24 2018
