ONTAP commands
network cloud routing-table create
Create a new external routing table
The network cloud routing-table create command creates a new external routing table.
-route-table-id <text> - Route Table ID (privilege: advanced)
This parameter is used to provide the name of the external routing table to be created.
The following example creates an external routing table "eni-123456":
cluster1::> network cloud routing-table create -route-table-id eni-123456
