The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
system node root-mount create
PDF of this doc site
Creating your file...
Your file is ready
Create a mount from one node to another node's root volume.
The system node root-mount create
command produces a root-mount from one node in the cluster to another node's root volume. The root-mount is marked for immediate creation by a background task. Use the system node root-mount show command to view the current status of root-mount or verify task completion.
-node <nodename>
- Owner of the Root-mount-
The node name where the root-mount will be created.
-root-node <nodename>
- Root-mount Destination Node-
The node name that the root-mount will access.
The following example shows the creation of a root-mount from cluster1::nodeA
to cluster1::nodeB
and the verification of the successful completion.
cluster1::> system node root-mount show This table is currently empty. cluster1::> system node root-mount create -node nodeA -root-node nodeB cluster1::> system node root-mount show Node Root Node State Last Error ----------------- ----------------- ----------- ------------------------------- nodeA nodeB ready
