security session limit location modify
Modify per-location session limit
This command allows modification of a per-location management session limit.
-interface {cli|ontapi|rest}
- Interface-
The interface (CLI, ONTAPI, or REST) to which the limit applies.
-location <text>
- Location-
The specified location to which this limit applies. The limit with the location name
-default-
(in theDefault
IPspace) is the limit used for any location (in any IPspace) without a specific configured limit. [-ipspace <IPspace>]
- IPspace of Location-
This identifies the IPspace of the client location. If not specified, changes are made in the
Default
IPspace. [-max-active-limit <integer>]
- Max-Active Limit-
The maximum number of concurrent sessions allowed for this interface and location.
The following example illustrates modifying management sessions limits for specific locations.
cluster1::*> security session limit location modify -interface * -location 10.98.* -max-active-limit 2 3 entries were modified.
