system controller show
Display the controller information
The system controller show
command displays information about all the controllers in the cluster. These commands are available for 80xx, 25xx and later systems. Earlier models are not supported. By default, the command displays the following information about all the controllers in the cluster:
Controller name
System ID
System serial number
Controller model name
Health monitor status
To display more details, use the -instance parameter.
[-fields <fieldname>,…]
Selects the fields that you specify.
[-instance ]
Displays detailed information about all the controllers in the cluster.
[-node {<nodename>|local}]
- Node-
Selects information about the specified controller.
[-system-id <text>]
- System ID-
Selects information about the controller with the specified System ID.
[-model <text>]
- Model Name-
Selects information about the controllers with the specified model name.
[-part-number <text>]
- Part Number-
Selects information about the controllers with the specified part number.
[-revision <text>]
- Revision-
Selects information about the controllers with the specified revision.
[-serial-number <text>]
- Serial Number-
Selects information about the controller with the specified system serial number.
[-controller-type <text>]
- Controller Type-
Selects information about the controllers with the specified controller type.
[-status {ok|ok-with-suppressed|degraded|unreachable|unknown}]
- Status-
Selects information about the controllers with the specified health monitor status.
[-chassis-id <text>]
- Chassis ID-
Selects information about the controllers with the specified chassis ID.
The below example displays information about all controllers in the cluster.
cluster1::> system controller show Controller Name System ID Serial Number Model Status ------------------------- ------------- ----------------- -------- ----------- node1 140733730268652 700001456939 FAS2520 ok node2 140733730268667 700001456941 FAS2520 ok 2 entries were displayed.
The example below displays detailed information about specified controller in the cluster.
cluster1::> system controller show -instance -node node1 Node: node1 System ID: 140733730268652 Model Name: FAS2520 Part Number: 111-01316 Revision: 21 Serial Number: 700001456939 Controller Type: none Status: ok Chassis ID: 4591227214
