network interface show
Display logical interfaces
The network interface show command displays information about logical interfaces.
Running the command with the -failover parameter displays information relevant to logical interface failover rules.
Running the command with the -status parameter displays information relevant to logical interface operational status.
Running the command with the -by-ipspace parameter displays information relevant to logical interfaces on a specific IPspace.
See the examples for more information.
You can specify additional parameters to display only information that matches those parameters. For example, to display information only about logical interfaces whose operational status is down, run the command with the -status-oper down parameter.
[-fields <fieldname>,…] -
If you specify the
-fields <fieldname>,…parameter, the command displays only the fields that you specify. - |
[-by-ipspace ] -
Use this parameter to display logical-interfaces sorted by IPspace and Vserver.
[-dns-zones ] -
Use this parameter to display logical-interfaces and whether the interface is associated with a Domain Name System (DNS) load balancing zone.
[-failover ] -
Use this parameter to display logical-interface failover information.
[-status ] -
Use this parameter to display detailed logical-interface status information.
[-instance ]} -
Use this parameter to display all the fields for the specified logical-interfaces.
[-vserver <vserver>]- Vserver Name-
Use this parameter to display information only about logical interfaces on the Vserver you specify.
Use this parameter plus the
-lifparameter to display detailed information only about the logical interface you specify. [-lif <lif-name>]- Logical Interface Name-
Use this parameter to display information only about logical interfaces that match the name you specify.
Use this parameter with the
-vserverparameter to display detailed information only about the logical interface you specify. [-service-policy <text>]- Service Policy-
Use this parameter to display information only about logical interfaces that have the service policy you specify.
[-services <LIF Service Name>,…]- Service List-
Use this parameter to display information only about logical interfaces that support all services in a comma-separated list of service names.
[-role {cluster|data|node-mgmt|intercluster|cluster-mgmt}]- (DEPRECATED)-Role-
This parameter has been deprecated and may be removed in a future version of ONTAP. Use either the -service-policyor-servicesparameter instead.Use this parameter to display information only about logical interfaces that are associated with network ports that have the role you specify.
[-data-protocol {nfs|cifs|iscsi|fcp|fcache|none|fc-nvme}]- Data Protocol-
Use this parameter to display information only about logical interfaces that have the enabled data protocols you specify.
[-address <IP Address>]- Network Address-
Use this parameter to display information only about logical interfaces that match the IP address or address range you specify.
[-netmask <IP Address>]- Netmask-
Use this parameter to display information only about logical interfaces that have the netmask you specify.
[-netmask-length <integer>]- Bits in the Netmask-
Use this parameter to display information only about logical interfaces with a netmask that has the number of bits you specify.
[-is-vip <true>]- Is VIP LIF-
Use this parameter to display information only about logical interfaces that are VIP LIFs or not as you specify.
[-subnet-name <subnet name>]- Subnet Name-
Use this parameter to display the logical interfaces that matches the subnet name.
[-home-node <nodename>]- Home Node-
Use this parameter to display information only about logical interfaces that have the home node you specify.
[-home-port {<netport>|<ifgrp>}]- Home Port-
Use this parameter to display information only about logical interfaces that have the home port or interface group you specify.
[-curr-node <nodename>]- Current Node-
Use this parameter to display information only about logical interfaces that are currently located on the node you specify.
[-curr-port {<netport>|<ifgrp>}]- Current Port-
Use this parameter to display information only about logical interfaces that are currently located on the port or interface group you specify.
[-status-oper {up|down}]- Operational Status-
Use this parameter to display information only about logical interfaces that have the operational status you specify.
[-status-extended <text>]- Extended Status-
Use this parameter to display information only about logical interfaces that match the extended status that you specify.
[-numeric-id <integer>]- Numeric ID (privilege: advanced)-
Use this parameter to display information only about logical interfaces with the numeric ID (or range of IDs) you specify. The numeric ID is an integer that identifies the logical interface in the cluster.
[-is-home {true|false}]- Is Home-
Use this parameter to display information only about logical interfaces that are (true) or are not (false) currently located on their home node and port.
[-status-admin {up|down}]- Administrative Status-
Use this parameter to display information only about logical interfaces that have the administrative status you specify.
[-failover-policy {system-defined|local-only|sfo-partner-only|disabled|broadcast-domain-wide}]- Failover Policy-
Use this parameter to display information only about logical interfaces that use the failover policy you specify.
[-firewall-policy <policy>]- Firewall Policy-
Use this parameter to display information only about logical interfaces that use the firewall policies you specify.
[-auto-revert {true|false}]- Auto Revert-
Use this parameter to display information only about logical interfaces that have auto-revert setting you specify.
[-sticky {true|false}]- Sticky Flag (privilege: advanced)-
Use this parameter to display information only about logical interfaces that are "sticky". A sticky logical interface is one that has been manually migrated to another node and is not subject to auto-revert settings. A sticky logical interface remains at the migrated location until it is manually reverted or until it fails over to another node.
[-dns-zone {<zone-name>|none}]- Fully Qualified DNS Zone Name-
Use this parameter to display information only about logical interfaces in the specified DNS zone.
[-listen-for-dns-query {true|false}]- DNS Query Listen Enable-
Use this parameter to display information only about logical interfaces that have the DNS query listen value you specify.
[-allow-lb-migrate {true|false}]- (DEPRECATED)-Load Balancing Migrate Allowed (privilege: advanced)-
This parameter has been deprecated and may be removed in a future version of Data ONTAP. Use this parameter to display information only about logical interfaces for which load balancing migration is activated (true) or not activated (false).
[-lb-weight {load|0..100}]- Load Balanced Weight (privilege: advanced)-
Use this parameter to display information only about logical interfaces that have the load balancing weight you specify.
[-failover-group <failover-group>]- Failover Group Name-
Use this parameter to display information only about logical interfaces that are in the failover group you specify. Logical interfaces in the same failover group are capable of failing over to the same set of ports.
[-wwpn <text>]- FCP WWPN-
Use this parameter to display information only about logical interfaces that have the Fibre Channel Protocol port identifier (World Wide Port Name) you specify.
[-address-family {ipv4|ipv6|ipv6z}]- Address family-
Use this parameter to view the address family that is in use on the interface. Only IPv4 and IPv6 non-zoned addresses can be configured. Configuration of IPv6z addresses is not allowed.
[-comment <text>]- Comment-
Use this parameter to display information only about logical interfaces that have the comment you specify.
[-ipspace <IPspace>]- IPspace of LIF-
Use this parameter to display information only about logical interfaces on the IPspace you specify.
[-is-dns-update-enabled {true|false}]- Is Dynamic DNS Update Enabled?-
Use this parameter to display information only about logical interfaces that have (true) or do not have (false) dynamic DNS updates enabled for them.
[-probe-port <integer>]- Probe-port for Azure ILB-
Use this parameter display the probe-port for the logical interface in the Azure environment.
The following example displays general information about all logical interfaces.
cluster1::> network interface show
Logical Status Network Current Current Is
Vserver Interface Admin/Oper Address/Mask Node Port Home
cluster1
cluster_mgmt
up/up 192.0.2.1/192 node0 e0M true
node0_mgmt1
up/up 192.0.2.2/192 node0 e0M true
node1_mgmt1
up/up 192.0.2.3/192 node1 e0M true
Cluster
node0_clus1
up/up 192.0.2.66/192 node0 e0a true
node0_clus2
up/up 192.0.2.67/192 node0 e0b true
node1_clus1
up/up 192.0.2.68/192 node1 e0a true
node1_clus2
up/up 192.0.2.69/192 node1 e0b true
The following example displays failover information about all logical interfaces.
cluster1::> network interface show -failover
Logical Home Failover Failover
Vserver Interface Node:Port Policy Group
cluster1
cluster_mgmt node0:e0M broadcast-domain-wide
Default
Failover Targets: node0:e0M,
node0:e0d,
node0:e0e,
node0:e0f,
node1:e0M,
node1:e0d,
node1:e0e,
node1:e0f
node0_mgmt1 node0:e0M local-only Default
node0:e0d,
node0:e0e,
node0:e0f
node1_mgmt1 node1:e0M local-only Default
Failover Targets: node1:e0M,
node1:e0d,
node1:e0e,
node1:e0f
Cluster
node0_clus1 node0:e0a local-only Cluster
Failover Targets: node0:e0a,
node0:e0b
node0_clus2 node0:e0a local-only Cluster
Failover Targets: node0:e0b,
node0:e0a
node1_clus1 node1:e0a local-only Cluster
Failover Targets: node1:e0a,
node1:e0b
node1_clus2 node1:e0a local-only Cluster
Failover Targets: node1:e0b,
node1:e0a
