ONTAP commands
snaplock event-retention policy modify
Modify SnapLock Event Based Retention policies for a Vserver
The snaplock event-retention policy modify command is used to modify the retention period of an Event Based Retention (EBR) policy for a Vserver. Only a user with security login role vsadmin-snaplock is allowed to perform this operation.
-vserver <vserver name> - Vserver Name
Specifies the name of the Vserver for which retention period of a policy needs to be modified.
-name <text> - Policy Name
Specifies the name of the EBR policy for which the retention period needs to be modified.
[-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}] - Event Retention Period
Specifies the new value of retention period.
The following example modifies the retention period of policy "p1" for Vserver "vs1" to "5 years" :
vs1::> snaplock event-retention policy modify -name p1 -retention-period "5 years"
