The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
storage firmware acp show
PDF of this doc site
Creating your file...
Your file is ready
Display the list of ACP firmware files on the given node
The storage firmware acp show
command displays the ACP processor firmware files present on each node.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-node {<nodename>|local}]
- Node-
Selects the files that match the specified node name.
[-filename <text>]
- Storage Firmware File-
Selects the files that match the specified filename.
The following example displays the ACP processor firmware files on each node:
cluster1::> storage firmware acp show Node: Node1 ACP Firmware Files ---------------------------------------- ACP-IOM3.0150.AFW.FVF ACP-IOM3.AFW ACP-IOM6.0210.AFW ACP-IOM6.0210.AFW.FVF Node: Node2 ACP Firmware Files ---------------------------------------- ACP-IOM3.0150.AFW.FVF ACP-IOM3.AFW ACP-IOM6.0210.AFW ACP-IOM6.0210.AFW.FVF 8 entries were displayed.
