system feature-usage show-summary
PDF of this doc site
Creating your file...
Display Feature Usage Summary
Display usage summary information about features in the cluster on a per-node basis. The summary information includes counter information such as the number of weeks the feature was in use and the last date and time the feature was used. Additional information can also be displayed by using the -instance parameter.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-serial-number <Node Serial Number>]
- Node Serial Number-
Displays usage summary information for the specified serial number.
[-feature-name <Managed Feature>]
- Feature Name-
Displays usage summary information for the specified feature name.
[-weeks-in-use <integer>]
- Weeks In-Use-
Displays usage summary information for features matching the number of weeks in use.
[-last-used <MM/DD/YYYY HH:MM:SS>]
- Date last used-
Displays usage summary information for features last used on the specified date.
[-owner <text>]
- Owner-
Displays usage summary information for the specified owner name.
[-weeks-not-used <integer>]
- Weeks Not Used-
Displays usage summary information for features matching the number of weeks not in use.
[-weeks-configured <integer>]
- Weeks Configured-
Displays usage summary information for features matching the number of weeks that the feature was in configuration.
[-weeks-not-available <integer>]
- Weeks Data Not Available-
Displays usage summary information for features matching the number of weeks when usage data was not available.
The following example displays a usage summary output for a cluster of two nodes:
cluster1::> system feature-usage show-summary Node Serial Number: 1-81-0000000000000001122334455 Owner: node1 Feature Name Weeks In Use Date Last Used ------------ ----------------- -------------------- CIFS 10 1/1/2013 23:27:49 NFS 15 1/8/2013 23:48:03 Node Serial Number: 1-81-0000000000000001122334466 Owner: node2 Feature Name Weeks In Use Date Last Used ------------ ----------------- -------------------- CIFS 10 1/1/2013 23:26:38 NFS 20 1/8/2013 23:46:48 4 entries were displayed.
