The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
vserver iscsi security add-initator-address-ranges
PDF of this doc site
Creating your file...
Your file is ready
Add IP Address Ranges
Add IP address ranges to an existing iSCSI security entry
-vserver <Vserver Name>
- Vserver-
Specifies the Vserver.
-i, -initiator-name <text>
- Initiator Name-
Specifies the initiator.
-initiator-address-ranges {<ipaddr>|<ipaddr>-<ipaddr>}
- Initiator IP Address Ranges-
Specifies one or more initiator source IP address range. The IPv4 or IPv6 address range contains a start address and an end address. The start and end addresses themselves are included in the range.
An example of a valid IPv4 address range is: '192.168.1.100-192.168.1.150'.
An example of a valid IPv6 address range is: '2001:db8::1000:1-2001:db8::1000:50'.
cluster1::> vserver iscsi security add-initator-address-range -vserver vs1 -initiator-name iqn.1993-08.com.example:01:e3f87c7cf2e4 -initiator-address-range 192.168.2.1-192.168.2.255
Adds the IP address range 192.168.2.1-192.168.2.255 to initiator iqn.1993-08.com.example:01:e3f87c7cf2e4 for vserver vs1.
