The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
statistics settings modify
PDF of this doc site
Creating your file...
Your file is ready
Modify settings for the statistics commands
This command modifies the settings for all of the statistics
commands.
[-display-rates {true|false}]
- Display Rates (privilege: advanced)-
Specifies whether the
statistics
commands display rate counters in rates/second. The default is true. [-client-stats {enabled|disabled}]
- Collect Per-Client Statistics (privilege: advanced)-
Specifies whether
statistics
commands display per-client information. The default is disabled.If you enable this setting, you might significantly impact system performance. [-counter-display-units {B|KB|MB|GB}]
- Counter Display Units (privilege: advanced)-
Specifies display units for the counters. The default setting is MB.
[-display-count-exponent <integer>]
- Display Count Exponent (privilege: advanced)-
Specifies display exponent value for the counters representing counts. The default setting is 3 (thousand).
The following example sets the value of the -display-rates
parameter to false :
cluster1::*> statistics settings modify -display-rates false
