system health autosupport trigger history show
View system health alert history
The system health autosupport trigger history show command displays all the alert triggers in the cluster that generated the AutoSupport messages. The following fields are displayed in the output:
Node name
Monitor name
Subsystem
Alert identifier
Alerting resource
Severity
If an AutoSupport has been sent due to this alert
- { [-fields <fieldname>,…]
Use this parameter to display only the fields you specify.
- | [-instance ]}
Use this parameter to display additional information about all of the alerts that were generated.
- [-node {<nodename>|local}]- Node
Use this parameter to display AutoSupport trigger history on the specified node.
- [-monitor <hm_type>]- Monitor
Use this parameter to display AutoSupport trigger history with the specified monitor name.
- [-alert-id <text>]- Alert ID
Use this parameter to display the AutoSupport message that was triggered by the specified alert ID.
- [-alerting-resource <text>]- Alerting Resource
Use this parameter to display the AutoSupport message that was triggered by the specified alerting resource.
- [-subsystem <hm_subsystem>]- Subsystem
Use this parameter to display the AutoSupport message that was triggered by the specified subsystem.
- [-indication-time <Date>]- Indication Time
Use this parameter to display the AutoSupport message that was triggered at the indicated time.
- [-perceived-severity <hm_perceived_sev>]- Perceived Severity
Use this parameter to display the AutoSupport message that was triggered by alerts with the specified perceived severity.
- [-autosupport-triggered {true|false}]- AutoSupport Triggered
Use this parameter to display the alerts that generated AutoSupport messages.
- [-probable-cause <hm_probable_cause>]- Probable Cause
Use this parameter to display the alerts that were generated with the specified probable cause.
- [-corrective-actions <text>]- Corrective Actions
Use this parameter to display the AutoSupport alerts with the specified corrective actions.
- [-asup-enable {true|false}]- Enable Asup for This Alert
Use this parameter to enable or disable an AutoSupport message for this alert.
- [-alert-clear-time <Date>]- Alert Clear Time
Use this parameter to display the alerts that were cleared at a given time.
This example displays information about the AutoSupport trigger history
cluster1::> system health autosupport trigger history show
Node           Monitor                Subsystem         Alert ID
node1          node-connect           SAS-connect       DualPathToDiskShelf_
                                                        Alert
     Resource: 50:05:0c:c1:02:00:0f:02
     Severity: Major
    AutoSupport sent: true
This example displays info about the autosupport trigger history in detail
cluster1::> system health autosupport trigger history show -instance
                      Node: node1
                   Monitor: node-connect
                  Alert ID: DualPathToDiskShelf_Alert
         Alerting Resource: 50:05:0c:c1:02:00:0f:02
                 Subsystem: SAS-connect
           Indication Time: Thu Mar 17 11:59:09 2011
        Perceived Severity: Major
     AutoSupport Triggered: true
            Probable Cause: Connection_establishment_error
        Corrective Actions: 1. Halt controller node1 and all controllers attached to disk shelf 2.
2. Connect disk shelf 2 to controller node1 via two paths following the rules in the Universal SAS and ACP Cabling Guide.
3. Reboot the halted controllers.
4. Contact support personnel if the alert persists.
Enable asup for this alert: true
          Alert Clear Time: Wed May 29 16:10:13 2013
 PDFs
PDFs
