snaplock log show
Display audit log configuration.
The snaplock log show command displays the following information about the SnapLock log infrastructure:
Vserver name
Volume name
Maximum log size
Default retention period
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-vserver <vserver name>]- Vserver Name-
If this parameter is specified, the command displays the log information for Vserveers that match the specified value.
[-volume <volume name>]- Log Volume Name-
If this parameter is specified, the command displays the log configuration for volumes that match the specified value.
[-max-log-size {<integer>[KB|MB|GB|TB|PB]}]- Maximum Size of Log File-
If this parameter is specified, the command displays the log configuration with a matching
-max-log-sizevalue. [-default-retention-period {{<integer> seconds|minutes|hours|days|months|years} | infinite}]- Default Log Record Retention Period-
-default-retention-periodvalue.
cluster1::> snaplock log show -vserver vs1
Vserver Name : vs1
Log Volume Name : 15MB
Maximum Size of Log File : 15MB
Default Log Record Retention Period : 6 months
Vserver Volume Maximum Size Retention Period
vs1 vol1 15MB 6 months
