cluster peer health show
PDF of this doc site
Creating your file...
Check peer cluster health
The cluster peer health show
command displays information about the health of the nodes in peer clusters from the perspective of the nodes in the local cluster. The command obtains health information by performing connectivity and status probes of each peer cluster's nodes from each node in the local cluster.
To enable quick access to remote cluster health information, remote cluster health status is periodically checked and cached. These cached results enable users and system features to quickly assess the availability of remote resources. By default, this command accesses cached results. Use the -bypass-cache
true
option to force a current, non-cached check of remote cluster health.
[-fields <fieldname>,…]
If you specify the
-fields <fieldname>, …
parameter, the command output also includes the specified field or fields. You can use '-fields ?' to display the fields to specify. - |
[-instance ]
If you specify the
-instance
parameter, the command displays detailed information about all fields. [-originating-node {<nodename>|local}]
- Local Node-
Selects the node that matches this parameter value.
[-destination-cluster <Cluster name>]
- Peer Cluster-
Selects the cluster that matches this parameter value.
[-destination-node <Peer Node Name>]
- Peer Node-
[-destination-cluster-uuid <UUID>]
- Peer UUID-
[-data-ping {unknown_node|internal_error|unreachable|session_reachable|interface_reachable}]
- Status of Data Ping Operation-
Selects the nodes that match this parameter value.
[-icmp-ping {unknown_node|internal_error|unreachable|session_reachable|interface_reachable}]
- Status of ICMP Ping Operation-
[-node-health {true|false}]
- RDB Health of the Node-
Selects the nodes that match this parameter value (
true
means healthy). [-cluster-health {true|false}]
- Cluster Health-
true
means healthy). [-availability {true|false}]
- Communication Indicator-
true
means communicating). [-bypass-cache {true|false}]
- Bypass Cache and Determine Health-
Bypasses cached results to determine current cluster health (
true
means bypass the cache). Cached results may not be current, but they are displayed more quickly. [-last-updated <MM/DD/YYYY HH:MM:SS>]
- Last Update Time-
The following example shows typical output for this command in a cluster of two nodes that has a peer cluster of two nodes.
cluster1::> cluster peer health show Node Cluster-Name Node-Name Ping-Status RDB-Health Cluster-Health Availability ---------- --------------------------- --------- --------------- ------------ node1 cluster2 node3 Data: interface_reachable ICMP: interface_reachable true true true node4 Data: interface_reachable ICMP: interface_reachable true true true node2 cluster2 node3 Data: interface_reachable ICMP: interface_reachable true true true node4 Data: interface_reachable ICMP: interface_reachable true true true 4 entries were displayed.
The following example shows detailed health information for node3 in cluster2 from the perspective of node1 in cluster1.
cluster1::> cluster peer health show -originating-node node1 -destination-cluster cluster2 -destination-node node3 -instance Local Node: node1 Peer Cluster: cluster2 Peer Node: node3 Peer UUID: 5e4befb2-1f36-11d0-98c9-123476563412 Status of Data Ping Operation: interface_reachable Status of ICMP Ping Operation: interface_reachable RDB health of the node: true Cluster Health: true Communication Indicator: true Last Update Time: 02/06 18:58:38
