volume mount
Mount a volume on another volume with a junction-path
The volume mount
command mounts a volume at a specified junction path.
-vserver <vserver name>
- Vserver Name-
This specifies the Vserver on which the volume is located.
-volume <volume name>
- Volume Name-
This specifies the volume that is to be mounted.
-junction-path <junction path>
- Junction Path Of The Mounting Volume-
This specifies the junction path of the mounted volume. The junction path name is case insensitive and must be unique within a Vserver’s namespace.
[-active {true|false}]
- Activate Junction Path-
This optionally specifies whether the mounted volume is accessible. The default setting is
false
. If the mounted path is not accessible, it does not appear in the Vserver’s namespace. [-policy-override {true|false}]
- Override The Export Policy-
This optionally specifies whether the parent volume’s export policy overrides the mounted volume’s export policy. The default setting is
false
The following example mounts a volume named user_tsmith on a Vserver named vs0. The junction path for the mounted volume is /user/tsmith. The mounted volume is accessible, and the mounted volume’s export policy is not overridden by the parent volume’s export policy.
node::> volume mount -vserver vs0 -volume user_tsmith -junction-path /user/tsmith -active true -policy-override false
