ONTAP commands
volume flexcache connection-status show
Display FlexCache Connection Status
The volume flexcache connection-status show command displays information about the connection status of FlexCache volumes and origin of FlexCache volumes. The command output depends on the parameter or parameters specified with the command. If no parameters are specified, the command displays the following information about connection status of all FlexCache volumes:
  • Node
  • Vserver
  • Volume
  • Remote Vserver
  • Remote Volume
  • Remote Endpoint
  • Connection Status
To display detailed information about all FlexCache volumes, run the command with the -instance parameter.
{ [-fields <fieldname>,…​]
This specifies the fields that need to be displayed.
| [-instance ] }
If this parameter is specified, the command displays information about all values.
[-node {<nodename>|local}] - Node Name (privilege: advanced)
If this parameter is specified, the command displays detailed information the connection status of all the FlexCache volumes and origin of FlexCache volumes on this node.
[-vserver <vserver name>] - Vserver Name (privilege: advanced)
If this parameter and the -volume parameter are specified, the command displays detailed information about the specified volume. If this parameter is specified by itself, the command displays information about FlexCache volumes and origin of FlexCache volumes on the specified Vserver.
[-volume <volume name>] - Local Volume (privilege: advanced)
If this parameter is specified, the command displays detailed information about the specified FlexCache volume and origin of FlexCache volumes.
[-remote-vserver <vserver name>] - Remote Vserver (privilege: advanced)
If this parameter is specified, the command displays information only about the FlexCache volume or volumes which have a relationship with the specificed remote-vserver.
[-remote-volume <volume name>] - Remote Volume (privilege: advanced)
If this parameter is specified, the command displays information only about the FlexCache volume or volumes that have a relationship with the specified remote-volume.
[-remote-cluster <Cluster name>] - Remote Cluster (privilege: advanced)
If this parameter is specified, the command displays information only about the FlexCache volume or volumes which have a relationship with the specificed remote-cluster.
[-conn-status {unknown|connected|disconnected|downrev}] - Connection Status (privilege: advanced)
If this parameter is specified, the command displays information only about the FlexCache volume or volumes that have connection status as specified by conn-status.
[-remote-endpoint {none|cache|origin}] - Remote Endpoint (privilege: advanced)
If this parameter is specified, the command displays information only about the FlexCache volume or volumes that have endpoint as specified by remote-endpoint.
The following example displays connection status of all FlexCache volumes on the Vserver named "vs_1":
node3::> flexcache connection-status show -vserver vs_1
Node: node3-01
Remote       Remote     Remote   Remote   Connection
+Vserver      Volume     Vserver      Volume     Cluster  Endpoint Status
vs_1          vol_origin vs_2         fc_2__0001 clus-4   cache    connected
vs_1          vol_origin vs_2         fc_2__0002 clus-4   cache    connected
vs_1          vol_origin vs_2         fc_2__0003 clus-4   cache    connected
vs_1          vol_origin vs_2         fc_2__0004 clus-4   cache    connected
4 entries were displayed.
