job schedule cron show
Show cron schedules
The job schedule cron show command displays information about cron schedules. A cron schedule runs a job at a specified time on specified days.
[-fields <fieldname>,…] -
If you specify the
[-instance ]} -
If you specify the
-instanceparameter, the command displays detailed information about all fields. [-cluster <Cluster name>]- Cluster-
Selects the cron schedules that match this parameter value.
 [-name <text>]- Name-
 [-month <cron_month>,…]- Month-
Selects the cron schedules that match this parameter value. Valid values are
January,February,March,April,May,June,July,August,September,October,November,December, orall. [-dayofweek <cron_dayofweek>,…]- Day of Week-
Selects the cron schedules that match this parameter value. Valid values include
Sunday,Monday,Tuesday,Wednesday,Thursday,Friday,Saturday, orall. [-day <cron_dayofmonth>,…]- Day-
Selects the cron schedules that match this parameter value. Valid values range from
1to31. [-hour <cron_hour>,…]- Hour-
 [-minute <cron_minute>,…]- Minute-
Selects the cron schedules that match the minute or range of minutes that you specify.
 [-description <text>]- Description-
The following example displays information about all current cron schedules:
cluster1::> job schedule cron show
Cluster       Name        Description
cluster1
              5min        @:00,:05,:10,:15,:20,:25,:30,:35,:40,:45,:50,:55
              8hour       @2:15,10:15,18:15
              weekly      Sun@0:15
The following example displays information about the cron schedule named weekly:
cluster1::> job schedule cron show -name weekly -instance
Cluster: cluster1
      Month: -
Day of Week: Sunday
        Day: -
       Hour: 0
     Minute: 15
Description: Sun@0:15
